re samsung note 10+ problem
(Topic created on: 05-11-2020 11:30 AM)
moondog2
Galaxy Note
Can anyone help, is there a problem with your note 10plus having issues with calls  eg cant hear other party sounds like a robot/ or static.
15 REPLIES 15
keagan
Galaxy Note
Hi moondog2,
Could you please explain what do you mean by "Other party sounds" and try to elaborate on the issue.
GG2
Expert Level 3
Galaxy Note
This won't help with your issue but my calls are crystal clear with my Note 10+.
Cassidy
Galaxy Note
When talking about other party sound, did you enable this feature ?
moondog2
Galaxy Note
just got off the phine with samsung support.. i spent over 5000 for 2 phones 10plus and warrenty
if you guys wants advice do not buy the warrenty they will not give you a new phone unless they decide which is never.
samsung expects me to keep sending my phone in for repair for the 4 time.
this stupid phone is only 5month old.
im done they have lost a loyal customer.
i was told by many samsung **bleep** they are right!!!!!!
SAMSUNG **bleep**!!!!!!!!!!!!!!!
moondog2
Galaxy Note
sorry cassidy, i will check to see if that is the issue
moondog2
Galaxy Note
Hi keagan, it sounds like the voice cuts in add out and cracky
Galaxy Note
Which Carrier are you with?
When you received your Note - Did you get a new SIM card with it?
It sounds more like a Network / SIM issue than a device issue...
If you haven't already - You could always Backup your device with Smart Switch & Factory Reset - It never hurts & can only help to rule out some issues... But - If it was me - I'd start with a new SIM card & go from there.
moondog2
Galaxy Note
Hi Cassidy l, should i have the hearing aid enabled , i looked and its not enabled
Galaxy Note
No you shouldn't unless you use a hearing aid.
