Wireless Charger Issues
(Topic created on: 11-13-2017 08:30 AM)
bett3r
Galaxy Note
I'm charging my Note 8 with no case, with original Samsung fast charging, to convertible wireless charger (EP-PG950) which I just bought from Samsung.
The issue is when I put it up to horizontal position it shows charging but when I woke up in the morning it says "not charging" with the battery remained the same as I left it the night before. However, when I charge it on flat position it does not have any problems. Help?
14 REPLIES 14
Jmak
Galaxy Note
Try different power brick and different outlet. If that don't fix your problem, wireless charger can be at fault so look for replacement or repair.
bett3r
Galaxy Note
Yup, already talked with Samsung support. They'll replace my unit.
Galaxy Note
are you using a case..it shouldn't matter but..sometimes can get in the way
bett3r
Galaxy Note
That's stupid actually for a product cost $129.99 can't handle a thin casing. But in this case, I wasn't.
Galaxy Note
total agree with you. mine works with the Samsung case I use but I haven't tried it horizontal....gonna try it tonight
bett3r
Galaxy Note
It did worked eventually. But you need to placed it at I certain angle I guess (??) sometimes it work sometimes it won't
Galaxy Note
that's soo bizzare
raydenray
Galaxy Note
happened twice for me but now seems to worl fine
bett3r
Galaxy Note
What did you do until it worked again?
