07-27-2019 10:00 AM in
07-27-2019 11:17 AM in
07-27-2019 12:19 PM in
07-27-2019 02:34 PM in
07-27-2019 03:00 PM in
07-27-2019 03:12 PM (Last edited 07-27-2019 03:12 PM ) in
Galaxy SStarting in Android 8, all notifications are assigned to a channel, so the user is able to choose which type of notification (s)he's willing to receive by either going to the Notifications settings or by swiping a notification and tapping on the gear icon beside it.
So, as far as it says, this option has nothing to do with your problem.
07-27-2019 03:23 PM in
Galaxy Swhen you select the tone here its noticeably low and no option to increase the volume. hopefully Facebook does an update soon to fix this. found ALOT of people having the same issue. :(
07-27-2019 05:42 PM in
Galaxy SSince I don't have any problem with the notification sound, if it helps you file a bug report, my app version is 231.0.0.39.113
07-28-2019 05:10 AM (Last edited 05-08-2020 05:57 PM ) in
