need help to recover deleted text messages
(Topic created on: 10-31-2018 07:48 PM)
terfer
4 REPLIES 4
jamesy
unless you backed it up you can't restore them. check your Samsung cloud, maybe you have it set to automatic backup.
Echo1
Expert Level 4
text messages are carrier ... So once you delete them they are gone and there is no way to recover them.
Moderator_
Hi @terfer, the only way you may be able to recover deleted text messages are if you have backed it up to Samsung Cloud @jamesy said. You can see if your messages could have been saved by going into Settings > Cloud and Accounts > Samsung Cloud > select the three dot icon (top right) > Settings > Auto backup settings. Check that the "Messages" option is toggled On and that the last backed up date/history catches the texts date that you want to recover. If this doesn't work, the only other options is if you backed them up elsewhere. Other then that, unfortunately there is no other way your texts messages can be recovered.
-Irene
mindl
then=next than=comparison. Two COMPLETELY different words. Think of the definitions and matching the common vowel and this not only will help with spelling but to better articulate. If nobody tells you, you'll never know.
