S22+ car charger or charging cable/cord
(Topic created on: 11-15-2022 02:01 PM)
TristaB
I recently got a Samsung Galaxy S22+.  But the cord that came with it has 2 small ends.  How do I charge it?  How do I plug it into my car?  (I've been using my old cords.)
10 Comments
RedDogRabbit
Can you post a picture of the Charging cable?
Ray1
Expert Level 3
S22s come with a c to c cable rather than the older usb to c cable
Ray1
Expert Level 3
You will have to use your old cables or purchase a new usb to c   cable if your vehicle has usb charging ports and if you do not have the right charging block to fit your cable to charge in a wall outlet you will have to buy a new charging block to use the cable that came with the phone
TristaB
Do newer cars come with c charging ports, instead of USB ports?
Ray1
Expert Level 3
New vehicles come with both usb and c charging ports but a new cable is way cheaper than buying a new vehicle😂
TristaB
Lol! Good point!
TristaB
Would something like this work?Screenshot_20221115-184800_Samsung Internet.jpg
Ray1
Expert Level 3
It should work just fine if all you are wanting to do is charge your phone and not connecting to your head unit for Android Auto in your car
TristaB
Oh, OK. A new charger it is then!
