S22 Ultra WiFi Problem with MAC address
(Topic created on: 06-09-2023 05:36 PM)
Hyzerik
So just recently my phone decided to kick me off my network and not allow me to reconnect with the same password saying it was incorrect.
Did some troubleshooting and found turning the wifi to Phone MAC from randomized MAC instantly solved it and allowed me to connect.
The reason for this post is to hopefully get this issue fixed to I can continue to use randomized MAC as I just like that better then my phones precise location.
Anyone know if there is anything I can do to get randomized back or will I just have to wait for an update eventually?
3 REPLIES 3
RedDogRabbit
I'd start with Resetting your Network Settings on your phone & Resetting the Router. I think that should resolve the issue for you.
Helenna
Hi, if you haven't tried to perform reset network settings on your device, please perform Reset Network settings on the device and check for the issue.
Go to Settings, and then select General management >> Find and select Reset >> Choose Reset network settings >> Tap on the Reset settings button >> Tap on the Reset button.
Reboot your device and check if it helps to solve the Wi-Fi issue.
I restarted my router and problem fixed. I am using linksys velop mesh system and S23U with randomized mac. Works fine with no problem. And Also no problem with my S22U.
Maybe check if router has new firmware to fix this problem since randomized mac is a trend now. Router manufacture should have fix this problem. Android has this feature since Android 10 and iOS 14 also implement such feature.
