S8 battery drain- cell standby
(Topic created on: 07-14-2019 11:24 PM)
Aldel11
Hi. I am running the newest version of Android on my S8. I was having an issue on the original release of Android 9 with the Play Store using lots of battery.  Now with the latest update that is solved but my Cell Standby is using more than 25% of battery over about 12hr time.
17 Comments
Geico
Same here on my S9
Weird - This is the Cell Standby time on my S9+ (AOD is a battery hog & not worth it imo) 🐧
fwiw - I ALWAYS Boot into Recovery and Wipe Cache after applying every OTA & Recently I also Performed a Factory Reset - Not issues with the Battery - Cell Standby Drain COULD be caused by poor Network service quality...
theonecid
There's a thread on reddit S9 saying to disable Adaptive battery and that it did wonders when they did. I'm trying that now
Aldel11
I also looked on reddit. Some users say using a text messaging app other than the stock Samsung messages can do this too. Im using Google messages right now. I'm gonna see how it goes today then try that.
theonecid
I use Google Messages too
Aldel11
Have you noticed any improvement with turning adaptive battery off?
theonecid
Not really. Too early to tell
fwiw - I use Android Messages on my devices.... 🐧
Aldel11
I've tried all this with no results:
1. Clear cache for Google messages
2. Clear cache in recovery boot
3. Change back to Samsung messages from Google messages
4. Turn off adaptive battery
My signal strength is usually between -95 and -87 dbm and always LTE.
I remember years ago there were problems with the bands were changing repeatedly but I wouldn't think that would be an issue any more?
