Samsung S9 plus Battery
(Topic created on: 01-15-2020 12:41 AM)
Aaron257
This symbol appears after I turn off my charger ...
 I usually charge the phone switched off ..
Does anyone know what the symbol means ??
3 Comments
just in case, clear device cache partition
Aaron257
I do that regularly
carr0498
Since you unplugged the power supply, i'm assuming the device is notifying you that it's no longer charging.  Don't think it's a cause for concern.
