Smart Lock - Trusted Devices Missing
(Topic created on: 09-21-2023 04:54 AM)
NewToSamsung
For the last couple of days I have had to constantly use my PIN or fingerprint to access my S23 Ultra. This morning I had a few minutes and looked in to why. I am an old codger and have hearing aids and I also have a Fitbit both of which I have set as trusted devices.
I was rather surprise to find Trusted Devices is missing from Settings -> Lock Screen -> Smart Lock.
I then wiped the cache partition and that did not help.
Is anyone else experiencing this issue? Any suggestions on how to resolve it?
84 REPLIES 84
Not applicable
Have you updated lately, I had an update come in last night (09/21/2023) at 11:00pm, and now "trusted devices" option no longer exists on my S21, making usage a lot more difficult to have to login to each device that previously auto-connected.
Samsung is going backwards now.  What a waste of my time.
Leeson
Have you tried searching for it in the search bar on the menu screen?
Not applicable
Yes, and it was no help.
Leeson
I found something online, try it. If it doesn't work, we'll check of your phone is updated to the latest software. It is apparently a common issue1695300191103_1695300191093_0.jpg
Not applicable
"Search the trust agent under settings", what the *** is that supposed to mean?
Taznut71
Beginner Level 3
Same with mine.
AlexE2
i have a s22 ultra and i dont have trusted devices anymore, i dont know when it disapeared
Not applicable
Same thing with my S21.    Does anybody have a fix?
Leeson
Trusted devices is gone. You can either use "on body detection " or set up a routine
RedDogRabbit
Trusted Devices wasn't there earlier today, then by following what I posted.. Trusted Devices is there again.
Others have reported the same thing.
