Smart Lock - Trusted Devices Missing
(Topic created on: 09-21-2023 04:54 AM)
NewToSamsung
For the last couple of days I have had to constantly use my PIN or fingerprint to access my S23 Ultra. This morning I had a few minutes and looked in to why. I am an old codger and have hearing aids and I also have a Fitbit both of which I have set as trusted devices.
I was rather surprise to find Trusted Devices is missing from Settings -> Lock Screen -> Smart Lock.
I then wiped the cache partition and that did not help.
Is anyone else experiencing this issue? Any suggestions on how to resolve it?
84 REPLIES 84
SkiBoggles
Beginner Level 4
Same issue, unlocked Z Flip 5
xraytedjim
Same issue here.  9to5 Google is reporting an issue/bug with Google Play Services.   Hopefully this will be fixed soon by Google with a play services update.  Very annoying.
Members_go5vLvb
Beginner Level 3
Same issue here. Can't see trusted devices at all under smart lock. S22. None of the suggested 'fixes' help at all. Used to have half a dozen or more different headphones or peripherals set to keep phone unlocked when paired. Can't see any of them anymore, or add new ones. Don't see routines as a solution myself.
Not applicable
Yep, Samsung is terrible, going backwards.
RedDogRabbit
Actually, I think that it's Google's Play Services, not Samsung's fault.
Leeson
Well well well, I had it this morning when u was helping put here, now it's gone 😆
Leeson
I found an alternative by setting up a routine. If phone is connected to a certain Bluetooth device, it will keep the phone unlocked for 4 hours
Leeson
SungSamOz
Looks like it is a reported issue - Smart Lock's Trusted devices missing from Pixel, Samsung (9to5google.com).
Mine was available yesterday but went missing late last night.
Not applicable
Yep, mine too last night, 11:03pm,  as the new updated was forced.
