Update ,net work issue : Wifi issue
(Topic created on: 01-22-2023 08:56 PM)
surej
After the recent update of S20fe 18 the January, there is a major issue with network,wifi signal issue ,video calls and audio calls are hardly affected .
I checked with my Another phone with the same wifi , it works well as usual . Only Samsung s20 fe after update ,it's so weird now ..do you guys have the issue?
8 REPLIES 8
theonecid
That's weird. Try rebooting the phone again. There shouldnt be an issue like that
surej
I had done everything , even resetted net work settings too ,still the same Video calls and audio calls are badly affected with this device
maxfield034
It might be the update that has caused the issue. You have to wait and I hope things will get better.
Also regularly check for updates, if you see any new update, then you should immediately update it.
surej
Sure, thank you
Try go to recovery mode and do wipe cache partition.
- Power off your phone
- Press and hold vol up and power key until you are in recovery mode
- use vol up and down to navigate
- select Wipe Cache Partition
- press power key to confirm
- click yes
- click reboot system
Give it a try.
Helenna
Hi surej, if you haven't tried to perform Wipe cache partition, we recommend you to follow the steps by Tallman to perform Wipe cache partition on your device and verify if your issue is resolved.
 Thank you Tallman.
If the issue still persists even after performing the above steps, then please perform backup and factory reset by following the steps in the given links.
https://www.samsung.com/ca/support/mobile-devices/how-to-transfer-and-backup-data-using-smart-switch...
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
surej
Thank you very much
Helenna
Hi surej, is your issue resolved after performing the above steps?
We request you to keep us posted, if your issue is solved.
