Resolved! Solved
Vibration is not working in call settings
(Topic created on: 03-15-2025 01:17 AM)
hsnmz
I have a S25 Ultra. Vibrate and sound alert isn't working when I answer or end a call. I have enabled the relevant settings as can be seen in the screenshot attached.
Helenna
Hi hsnmz,
Glad to hear you got it resolved! Sometimes switching default apps can reset settings or clear temporary glitches. Thanks for sharing your solution it might help others facing the same issue!
7 REPLIES 7
Turn off the device for 1-3 minutes everything should work after
hsnmz
Thanks, I tried it, turned it off for an hour but still didn't work.
Click Volume Up then the 3 dots. Make sure your Volume is up for system, notification and ringtone is up. Maybe this might help
hsnmz
Yes all the volumes are up but it's not working
hsnmz
My issue is resolved, Here's what I did.
I enabled the Google phone app as the default app and used it for a while. Then I switched back to the samsung phone app as the default app and now it is working.
Helenna
Hi hsnmz,
Sudharsanan
I had the same issue and finally found an solution.
Try to "Reset all settings" under Reset and this will fix all issue which is caused while transferring from smart switch.
