WiFi problems
(Topic created on: 04-13-2017 10:24 PM)
k3v1n
Is someone else having difficulties with the WiFi?
My phone keep disconnecting and reconnecting on WiFi like 10 times a day. Pretty sure my Internet is stable tho.
9 REPLIES 9
strando11
same problem after new software update
k3v1n
Thanks. Cool to know that I'm not alone. Let's hope for a fix on that.
Alaa
Hi
To try to fix this issue, did you try resetting your Wi-Fi on the modem? Try doing that and once the Wi-Fi has been reset try reconfiguring it with your phone and that should solve the issue.
Bawa
it's ur modem not ur phone. Goto modem settings n change frequency level from Auto to manual number 3 to 11 and see the difference.
izu
I've had the same issue after the updste. none of my other devices have this issue, motox lgg3, galaxy tab a. they all work fine except s7 with nougat
Idrees
same problem. never had this issue before the update now it happens all the time
Brett
anyone find a fix? can't connect to any WiFi hotspots at my work and it only started doing this after the 7.0 update
Emillionaire
I've had the same issue, I've switched to my 2.5ghz internet instead of my 5ghz and it seems to be fine. It might be 5ghz that's bugged with the phone. If its bugged for you on 2.5ghz try 5ghz. idk that might work
