Bluetooth problem
(Topic created on: 06-18-2018 08:31 AM)
Laki
Hi
My problem is when I did factory reset for my samsung s7 edge, I cannot communicate with my wi fi speakers.
9 REPLIES 9
You will have to set up as if you device was brand new - ie: when you first got your S7 🐧
Echo1
Expert Level 4
The update shouldn't make any difference but seeing as you can't connect then I would go into you Bluetooth settings and forget your speakers and the re-connect
Yeah I'm pretty sure that it's because he Factory Reset which wiped the previously paired devices from memory.
Echo1
Expert Level 4
glad you agree lol....
Moderator_
Hey @Laki, as other members mentioned, when you factory reset your device, it wipes all the network connection data as well. Please connect to your Wi-Fi speaker as it is your first time connecting. Thanks!
- Wonchul
Samesung
As of today my Bluetooth devices will randomly disconnect. Did everything single usual step to remedy the situation.
pink1
je ne peux pas accéder à mon bluetooth
ammaridris
my note 8 can't scan a new bluetooth headset
mikee04
cannot scan blue piston blue tooth speakers
