Charging issue on my s24 ultra
(Topic created on: 06-12-2024 05:32 PM)
Nidhin07
While charging with a 45w charger at first it shows say 50m until full but after few seconds it changes to 1h 48min till full. If anyone is facing this issue please help with the solution.
7 Comments
Nidhin07
Deeezzyyy
Facing same issue and seems like no1 has a fix for it. It started ever since the last update. I've tried many cables and 2 differents wall plugs, didn't not fix it at all.
Sometimes fast charge, sometimes normal slow charge.
No clue what is going on.
It now takes about 2hrs to charge my phone and it is extremely annoying
Helenna
 Hi Nidhin07 and Deeezzyy, we apologize for the buggy experience. We will monitor this issue and communicate to the relevant team.
However, you can try wiping cache partition and check if the solution fixes the issue.
Turn off the unit > Press and hold the volume up button and press and hold the on/off button. When the Android logo is displayed, release all keys ("Installing system update" is displayed before displaying the Android system recovery menu options) > Press the volume down key repeatedly to highlight "wipe cache partition" > Press the Power key to select. Press the Volume Down button to highlight "Yes" and press the Power button to select. When the wiping of the cache partition is completed, "Reboot System Now" is highlighted > Press the Power button to reboot the unit.
If the issue still occurs, we invite you to report the error through Samsung Members app by going to the 'Support' tab, scroll down to the 'Send feedback' section, click 'Error reports', and submit your report.
Thank you.
kekwkkwke
samsung phones only compatible with samsung chargers, but i wish for s25 they use apple battery suppliers with their optimized universal charging because they work with the best of the best like 165w wall charger with a 240w c to c cable, but if using heavy only samsung charger will work and still with fast charging turned off or else for mine the battery wont go up and will just keep heating and discharging which will cause damage over time but hopefully not like note 7 anymore because its looking way better than before for galaxys
Nidhin07
Samsung phones works well with any GaN chargers like anker's 25w , 45w , 65w etc
Day_Walker
I can confirm this with S23 and Anker 45W GaN charger. Unsure of Ultra models
bitnamus
Experiencing the same issue ever since last update, my fast charge and super faster charge stopped...
