need help resetting my s10
(Topic created on: 03-26-2021 09:38 PM)
momof2boyzz
I forgot my pincode and can't get it to unlock through find my device in the Samsung app or Google...... and im so frustrated that I will just do factory reset......somebody please help
6 REPLIES 6
RedDogRabbit
If you can't remember your pin / pattern, You'll still have to unlock it though Find my Device, as your phone has Factory Reset Protection (FRP). So a Factory Reset won't solve the problem.
momof2boyzz
but it won't unlock it.... it keeps saying something went wrong. the find my device also says its not connected to a network provider even though it says telus on my phone
momof2boyzz
samsung support keeps hanging up on me or telling me to call back in few hours
RedDogRabbit
Do you have Location turned on?
And forget Samsung support, contact your carrier.
Did you try Booting into Recovery and wipe cache or wipe cache & data for Find my Device?
I have a feeling the Find My Device has not enable on the phone.
Halston
Hi momof2boyzz,
Have you already configured your Samsung account and activated the Findmymobile option on your phone before it gets locked with the PIN? If yes, you can unlock your phone screen pattern or PIN by following the steps below using the Findmymobile link.
1. You must configure the Samsung account on your phone.
2. It is necessary to register on the "Findmymobile" site with the Samsung account which is registered on the phone.
3. Note: These steps only work if your phone is connected to Wi-Fi or the mobile network.
Click on the link below, sign in with the Samsung account. Your phone will be displayed as a registered device. Click Unlock my device and enter the Samsung account password to reset the phone lock screen: Https://findmymobile.samsung.com/
