Resolved! Solved
Network Issue with S20 Plus
(Topic created on: 03-17-2020 10:54 PM)
DJCorey
Not sure how many of you have experienced this or not, however, my new S20+ has a little bit of a glitch.
Whenever I leave a WiFi connection my phone will not connect to my providers network. Says there is no Sim card. So, I figured out on my own to restart my phone, then unlock it and then I'm magically connected!!!
So, of course I think I've done something wrong in my settings, contact Samsung and find out it is a known issue.
When asked, there is a patch coming for it. No timeline, just told to keep checking for updates. #annoyed #firstworldproblems #fixyourstuff
Resolved!
13 REPLIES 13
DJCorey
for sure, so far it seems like it has, see how it holds up over the next few days and give an update...
mytech
Expert Level 3
And mark this as a solution if it helped 👍
DJCorey
well, after several days of being home working off wifi I went to pick some things up and turned off my wifi and to my disappointment failed to connect to the network. So it seems I will have to wait for Samsung to come out with their patch as they do know of the issue and are working to release a patch. The saga continues...
Jamesg2
Hi mate are you having a problem like it connects but then after a few seconds it will disconnect from the network?  And what network you with? Three?
