S23 Ultra Slow charging issues
(Topic created on: 05-22-2024 04:57 AM)
Meet
Hello everyone, is anyone facing very slow charging with S23 Ultra after the 6.1 update that recently came in. I am using the 25W adapter which used to charge pretty fast (Super Fast Charger). Not sure what is happening because now it says 1 hr 5m to charge.
8 REPLIES 8
Vic20
No issues with super fast charging. Try clearing cache partition and see if that resolves the issue. Or toggle the setting, reboot and toggle again?
RedDogRabbit
Nope, no issues with my S23 Ultra One UI V6.1.
You don't say from what battery percentage it's taking 1 hour 5 minutes to reach 100% from?
It could also be an issue with Device Care's estimate of how long it will take to reach 100%
Device Care says that it'll take 26 minutes from 83%, but another app I use says 13 minutes.
But I did just recently clear both Cache & Data for Device Care... so it's likely "learning" again on my device.
Meet
It took nearly 15 mins from 20% to 23% even with super fast charger connected. It is very fast when charging at lower percentage. It says 1hr and 3 min to reach 80% because I have battery protection on.
RedDogRabbit
Open the Samsung Members app & Click on Support & run the Phone Diagnostics for the USB Connection, Cable Charging & Battery. See you get any error messages.
Meet
No errors at all 😑
Helenna
Hi Meet, we appreciate your efforts in trying all the necessary troubleshooting steps to solve the Slow charging issue on your Galaxy S23 Ultra.
Unfortunately, nothing works as a last resort, please perform backup and factory reset the device by following the steps in the given links.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-back-up-and-restore-data/
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-perform-a-factory-reset/
Thank you.
themmustangs
Beginner Level 3
I'm also having issues saw a post on the web with like 4k views and nothing has worked for me anyway to roll back to update before it was fine till I updated my phone if I could roll back to previous update that would be awesome, phone will charge fine for 20min then after that give me a crazy long time my s8 charges fine so I know it's not a issue with my cord or block, tests are fine I don't want to factory reset my phone if I can roll the update back then that would be awesome didn't have a issue till I decided to update my phone
themmustangs
Beginner Level 3
Fixed my issue what worked for me was going to the phone menu type in *#9900# go down to reset battery status, go to settings battery turn off fast charging and battery protection turn phone off and hold volume down and power wipe cash me I wiped the cash 5 times then reboot phone and re able fast charging but if I turn on battery protection it makes my phone have the issue it was having were i re do all the steps to fix it again that's what worked for me
